Sponsored by: CARiD
Power Steering "Heater" Delete
Old Aug 24, 2014 | 12:36 PM
Cole Train's Avatar
I'm talking the lines that go from the pump to the steering cooler. Did you reuse the stock hose/lines or the new hose included in the cooler kit?
Old Aug 24, 2014 | 01:54 PM
LS6427's Avatar
My temps BEFORE were about the same as "M4N14C"....210-215 driving in South Florida temps. That's friggin hot. And its just about the same as the coolant temps are.
AFTER the aftermarket cooler was put on my PS fluid temps would never go above 120*F......even in stop and go traffic on a 90*F day. I used a laser temp gauge.
BUT.....I think a big part of my cooler PS fluid temps is because of the cut-out I made in front of my cooler in the air dam.....so the cooler gets constant ram air cooling...not just static air....or some swirling air from forward movement. And NO....the cut-out has absolutely zero affect on coolant cooling.....
Old Aug 24, 2014 | 06:07 PM
M4N14C's Avatar
Oh, in that case kinda both
Stock lines weren't long enough to reach my cooler so I extended them with the ones included in the kit.
Yea I didn't cut the air dam. I could but I'm happy with 160.
Old Aug 24, 2014 | 07:14 PM
LS6427's Avatar
160 is way better than stock.....so that's good enough.
A couple friends I know just removed the factory cooler.......did not install an aftermarket cooler.....their temps dropped to around 170-180.....
Never do they reach 200-220.......like it does with the factory cooler on there. So it proves even without a cooler at all on there......it runs cooler than with the factory...."PS FLUID HEATER".......
Old Aug 24, 2014 | 07:32 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
A couple friends I know just removed the factory cooler.......did not install an aftermarket cooler.....their temps dropped to around 170-180......
This has been my observation as well. I didn't see anything higher than 18x on days up to 90°F (which is about as hot as it usually gets here in the summer), with most of the readings in the 160-180 range in average temps.
Old Aug 25, 2014 | 09:25 AM
wssix99's Avatar
Save the manuals!
This may prove true for places with hot climates and straight roads, but I'd be interested to see some data from folks in the Northeast and from racers.
I think the testing that RPM WS6 did a while back showed the potential for the stock system to raise fluid temperatures, but I don't think we really understand "why" GM put the system there in the first place. The stock system is inexpensive - so we can infer that cost is the reason why the design was chosen, but there must be some condition out there or set of circumstances that would cause the stock P/S system to rise in temperature way above 210*. I'm not sure we have found that, yet.
Old Oct 10, 2014 | 08:31 AM
Chevyguy2001's Avatar
I live in NY, Do i really need the PS Cooler??? I dont do any racing or auto X.
Old Oct 10, 2014 | 09:03 AM
RPM WS6's Avatar
Sounds like your climate and driving conditions are probably similar to mine.
So, in my opinion, you don't need one. Mine are/were fine without it.
Old Oct 10, 2014 | 09:13 AM
I dont drive it in the Winter anyway. Si all i would need is a new hose and reattach the PS cooler lines to to PS pump?
Old Oct 10, 2014 | 11:48 AM
M4N14C's Avatar
Pretty much, also you'll need some PS fluid as you will have to drain your reservoir when you disconnect the OEM cooler. Lots of options but after reading countless testimonies this stuff seems to be the best:
Old Oct 10, 2014 | 02:48 PM
dailydriver's Avatar
Yes, I can vouch for that stuff, as it is what all of the road racers use to prevent boilover problems, even with a very large power, air to fluid, steering cooler.
Old May 28, 2015 | 06:00 AM
  #32
6spdg37s's Avatar
so I noticed some PS sweat it looked like or maybe coolant near the cooler lines... so reading this it makes sense to possibly delete it...
