Oil Pressure questions
The Firehawk usually runs just a little higher...closer to 60.
blkZ28spt ... your gauge is as accurate as any other year
98s have accurate temp gauges but that's the only diff as far as I know ... what RPM do you drop to at a stop? and how how it your motor running?The hotter the motor the hotter the oil the thinner the oil... the lower the RPM the slower the oil pump is spinning (the oil pump is driven off the crank)
My car idles ~950RPM , 5w30 oil mobil 1 synthetic, engine temps ~190* and I sit at about 40 all the time... I hit 70-75 at WOT (ARE ported oil pump)
Edit: Oh yeah my engine is running fine so far as I can tell. Getting roughly the same mileage I always have (not good, basically, lol), runs strong enough, etc. I do have a pretty loud ticking but I've heard LS1's just do that, esp with headers.
Just for reference crusing I am at 50 psi, WOT Im at 60 or better, and at idle im 42-45.
I ran some seafoam in the oil and it got rid of my varying oil pressure.... mine would vary 5-6psi some days....
