Sponsored by: CARiD
Need electrical help, for real.
Old Sep 2, 2014 | 09:57 PM
bmorrow8's Avatar
Default Need electrical help, for real.
Hey guys, I need some help. Lately my truck has had a hard time starting. When I go to start it , I have nothing. I have a brand new battery, new alternator and new starter, new safety neutral switch, new relays. I think it's something having to do with the ignition. The electrical connection that goes to the starter solenoid is good. The weird thing is sometimes I'll let it sit if I can't get it to start and come back to it later.... sometimes, when it does actually start, If you hold the key down for like 10 seconds it will start but it doesn't happen much. Sometimes if I climb under the truck and wiggle the starter solenoid wire it will start if it's in the right spot but its not consistent, kinda rare too. Is there a problem at the ignition switch? could it be there gear shifter column or something around there? where should I start?
thanks
Old Sep 3, 2014 | 07:14 AM
fleetmgr's Avatar
I'd start with an ohmeter on the starter solenoid wire.
