Sponsored by: CARiD
leak found but what is it
Old Sep 7, 2014 | 05:34 PM
bunkerbuster's Avatar
Default leak found but what is it
Looked under my car this morning to find oil under my car. Looked under the car to find what you see in the attached picture. Looks to be some sort of oil line that is getting carved out by a steel bar going between the 2 front wheels. Perhaps the steel bar has enough play that whenever I hit a bump with my front wheels, it knocks it into that line.
The line is leaking a silver colored metallic lube, and every time I rub my finger over it, i hear a sound that is similar to pressurized air escaping. The sound stops after I stop rubbing over the carved out spot.
What am I looking at? I would say the countermeasure at this point is to found out what it is, replace it, and run it further away from that steel bar.
Engine is an LS3, in a WS6.
Last edited by bunkerbuster; Sep 7, 2014 at 05:35 PM. Reason: Forgot some underlying info
Old Sep 7, 2014 | 06:50 PM
Undertow74's Avatar
Well that line is hitting in your sway bar, and I am pretty sure it is you ac line coming from your compressor that it is rubbing through. A better picture would help but I'm pretty sure it's your ac line that's why you hear refrigerant leaking out.
Old Sep 8, 2014 | 07:41 AM
LS6427's Avatar
Undertow74........is correct.
I had to have that A/C line replaced for that exact same reason about 8 months ago. You will soon have no A/C once it rubs through and all your refrigerant sprays out.
I had it replaced under warranty at my dealer but that line is roughly $150.00 new. Probably one hour labor to install it.
BUT.....you need to replace BOTH front sway bar end links.......that is why it is rubbing the A/C line.
I personally zip tied a piece of rubber to my sway bar as a little bumper guard in case that ever happens again......so it won't rub through the A/C line again.....
