Electronic issues after valve spring swap.
2000 LS1-auto. Just replaced valve springs cause of cam swap. (Cam swap done while ago, just did springs)
What it very started with was my blinkers were slow. ooooooon, off, ooooooon, off. .... I believe first light to come on was TCS off (Button didnt work), then ABS and service vehicle came on. (Car has codes from EGR, AIR, delete etc.. I`ll check again later today though). After driving for maybe 10 minutes, my blinkers dont work at all, also all of my gauges turn off and twitch. Go home right away and turn it off. Wont start, makes tick..tick.tick. tick.tick.tick. clicking sound (Like dead battery kind of clicking sound, but battery is good). I found that after car sits for a little it will start back up.
It will start with just TCS off light being on, after ABS/SV comes on then it wont start. All my lights work yet though.
(One thing I noticed, not sure if relevant or not. the clip with a connecter on it that attaches to the TC unit is loose, I wasnt sure if it was ground or if it was just to hold it)
Thanks, it is very appreciated for anything.
The symptoms you describe are the same ones mine showed when the pump went bad.
Got looking around the alternator and then wouldn`t you know it! Seen the little red wire, which is suppose to plug into the alternator, was torn out of the quick connecter!! Explains why it wouldn`t charge.
Have to go to salvage yard tomorrow morning (45 minutes away) before my classes so I can hopefully get everything put back together and get it running. I might be getting a couple connecters in case it happens to me again.
