Sponsored by: CARiD
Vibration every 3 seconds on interstate.
Old Dec 7, 2014 | 12:51 AM
VandykeT/A's Avatar
Default Vibration every 3 seconds on interstate.
My 2000 z28 has a vibration every 3 seconds or so at 70 mph and above. It's noticeable at low speeds if your looking for it. Every 3 seconds it'll shake enough to move the passenger seat a few shakes and go away 3 seconds later it does it again. Control arms are new after markets, tires have been balanced, bearings are all good. Since it's not a constant shake I wouldn't think it would be a tire since at 70 mph the tire would be going over the bad spot more often than every 3 seconds or so. It's very consistent just has the delay between shakes. Motor mounts and trans mount are new also. Anybody got any ideas?
Old Dec 7, 2014 | 06:41 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
A friends Silverado had the same problem,turned out to be a bad tire belt. Because of the long time between the vibration,tires were not suspected.
Old Dec 7, 2014 | 04:24 PM
J.D.'s Avatar
most likely what he said ^^
Old Dec 8, 2014 | 03:22 AM
LS6427's Avatar
If your tires are all the same size.....move the fronts to the rears.....see if you get any change at all....
Or spend the cash and have them all put on a tire balance machine.
