Flushing heater core over winter break
Was wondering if fluid will be in the heater core when I take it out, I'm hoping I don't have to drain the coolant first but I will drain if I have to.
And what coolant would be good to top it off with?
If you are not overheating the engine....the heater core is probably as clean as it can be.
But....if you want to flush the heater core....just do a complete coolant system flush using a degreaser/water mix.
Easy way to clean the heater core:
Just pop BOTH heater core hoses off.....stick a hose in one of them and blast water through the heater core. Takes 5 minutes and the core is clean. You can also pour degreaser into one of the hoses to fill the heater core....let it sit for awhile....then blast it out with the hose.
PS. Sounds like it's giving heat just about as quick as I would expect in those outside temps on a cold start.
Vinegar is very mild acid and works great to clean the cooling system without harming anything. Baking soda is great for cleaning and neutralizing the system. I've done a bunch of very mucked up systems this way and it always works nice. If the heater core is really blocked you may need to let it sit for a few hrs after you put the vinegar in.
The heater core is the bypass in these systems so its the place all crap builds up.
Keep in mind that even putting a higher temp thermostat will not make it warm up faster, It doesn't matter if you have a 180* or a 195* both will be closed until the water temperature reaches the preset temp and that usually doesn't happen until you drive the car for a little bit.
If the temp gauge is showing that it's up to operating temperature and you still don't have heat then I would say you could have a problem with the heater core but if you let it run for 5-10 minutes and the temperature gauge is still reading low then it's probably not the heater core.
I would start by pulling the thermostat and test it, If it's stuck open you see that as soon as you remove it. If it's not open when you pull it you can test it by putting it and a thermometer in a pan of cold water on the stove and crank up the heat and watch for it to open. If it opens before the thermostats rating then it's bad. If it open at or near it's rating then you can eliminate that as a the problem.
I mean think about how thick or how gummy the coolant would have to get. Im sure its happened where the flow was slowed down.....but to stop the flow.....Id like to see what caused that to happen.
The worst Ive seen was a radiator where if you put your fingers down in there it had maybe 2mm's thick of black/brown sludge......because PS fluid was leaking into it for a very long time. But there was no overheating issue. We just opened it up to check after my friend said he keeps having to top off his PS fluid but he sees no leaks on the ground or under the hood. He said he probably poured 2-3 bottles in to top it off over about one year. He never checked his coolant. The overflow tank was also FULL of black crap. But is coolant flow was always sufficient to do its job.
True, I have a 180* stat to slow things a little, and no AC condenser blocking the LT1 replacement radiator (IF that has any bearing at all?), but I am lucky if I see even luke warm air after 15 minutes of highway driving!
Still, that quick core flush that LS6427 suggested above sounds like a good idea if you are not doing a complete system flush.
I wouldn't pull out the entire heater core out either, it's just because I want to hah. I'm a very hands on, visual learner + I have ample time to do it and I want to say I did it
I'll pull it Monday, I'll keep you guys updated on the before and after
I guess you didn't know that the major cause of corrosion in a cooling system is Electrolysis due to worn out acidic coolant. Some manufacturers even added ground straps to core to help alleviate the problem.
Thats why I also always carry one of these in my car.....just cut the ends even with a razor knife and put it in with the spare tire. If you ever spring a heater core leak, pop it on and keep going.
http://www.summitracing.com/parts/da...XYBhoC1u7w_wcB
