Sponsored by: CARiD
Flasher keeps blowing out
Old Dec 20, 2014 | 01:46 PM
THE LAST Z's Avatar
Default Flasher keeps blowing out
Im on my 4th flasher. They keep blowing out. The last one i had was an electronic flasher. It worked for a 2 weeks and then it started flashing faster and faster until it had a heart attack today. Now its stuck on. I changed the 2 front turn signal bulbs today. The front sockets look burnt, but they work.
Just checked all the bulbs. They are all good. Replaced the flasher AGAIN and seems to be working fine...for now.
Any clues?
Old Dec 20, 2014 | 07:09 PM
compton-z28's Avatar
hopefully someone chimes in man because mine is doin something similar
Old Dec 22, 2014 | 07:51 PM
rubeng's Avatar
Mine was doing the same thing, I found out that the bumper light was holding water. I removed it and drilled a small hole so it would drain, problem fixed.
Old Dec 23, 2014 | 12:45 PM
THE LAST Z's Avatar
Ahhh.. I will look into it thanks.
Old Dec 23, 2014 | 12:54 PM
98CayenneT/A's Avatar
It will happen when you get water in them, my front fixtures will pop a bulb whenever they get wet from washing the car or getting stuck in the rain they will usually pop shortly after. Need to replace the rotten fixtures and seal the new ones a bit better with silicone around the seams
Old Dec 23, 2014 | 02:47 PM
chrysler kid's Avatar
Pretty common problem on trans am's. You may need to replace the turn signal sockets as they can become rusty and corroded. At the very least clean them out thoroughly
