Help. Bad headlight motor?
You'll also get good info here: https://ls1tech.com/forums/pontiac-f...s-go-here.html
One thing I find weird is that after I have manually flipped up the light, when I turn the headlights off it flips it down no problem.
This is indicative of a stripped gear. The metal gear thing is not a silver bullet as they strip, too. After my loose motor housing stripped my metal gears, I went to a new Cardone motor with an access door to replace the gears. I'm back with Nylon now and everything has been great since.
Hardened metal = brittle. If your problem is not general age and fatigue, the brass or aluminum gears can break/strip faster than the nylon.
This is such a common thing, my metal gears arrived with a disclaimer that a loose motor body would still cause the metal ones to strip.
Yup. If you do, I'd suggest getting the Cardone's with the screw-on gear doors. You can replace 20 pairs of stripped out nylon gears for the price of one set of metal and this motor design makes that a snap.
https://ls1tech.com/forums/stereo-el...ght-doors.html
The way I resolved it, isn't exactly cheap, but it IS a permanent (I will never ever have to touch this again) fix. I purchased two BRAND NEW Cardone Headlight motors from RockAuto do NOT get the reman ones. The Brand New motors come with SCREWS on the housing, you can open the housing and replace the gear with a Phillips head screwdriver instead of prying the housing apart and gluing it back together.. When you get it, remove the Nylon Gear and install the Metal Gear. Now when you install the gear, MAKE SURE there is no play in the gear housing (as in the gear can't move side to side in the housing), if there is you WILL strip the metal gear (I've done this). I have found that the stock washers in the cardone gear are just slightly too thin. I resolved this by getting a slightly thicker washer and replacing the stock washer with it from Ace Hardware.. Re-install the motor and you should be okay.
http://forum.camarov6.com/showthread...eadlight+motor
