Sponsored by: CARiD
"BRAKE" light comes on when driving?
Old Feb 23, 2015 | 10:34 PM
210guy's Avatar
Default "BRAKE" light comes on when driving?
so the BRAKE light on my gauge cluster will go away as soon as I put the E-brake handle down but comes back after driving for a couple minutes. What would cause this? It just started happening after I installed my line lock. ive checked the fluid and its topped off. Any other reasons why this would happen?
Thanks!
Old Feb 24, 2015 | 05:48 PM
01SuperSport's Avatar
Do the abs inop and tcs lights turn on as well???
Old Feb 24, 2015 | 11:15 PM
wssix99's Avatar
Save the manuals!
A dirty brake handle switch can cause this. If you pop off the entire center console, you can detach the switch, take it apart, and clean it. If it collects enough dirt, the circuit it connects can brake and trigger the light.
Old Feb 25, 2015 | 08:03 PM
210guy's Avatar
yes but those have been on ever since i swapped over to a 3 channel 12 bolt.
Old Feb 25, 2015 | 08:04 PM
210guy's Avatar
thanks ill check that out
Old Feb 26, 2015 | 08:42 PM
210guy's Avatar
well i bled the brakes again and i disconnected abs/tcn wire i had plugged into the top of the center section of the rear end. that plug wasn't plugged in before. so it was either bleeding the brakes or that plug that was causing the brake light to come on? ha kinda weird oh well it doesn't come on anymore
