Diagnostic Help Please! Starting issues
There is no code for tight belts or hose issues.....so its a fuel/air/spark issue.
Or just a dirty MAF. I would get a $7.00 can of MAF cleaner and empty most of the can on the entire front of the MAF and also clean the back. Also spray the IAT sensor in the lid, or wherever it is on a 1995, and then the rest cleaning the TB blade.
See if that does the trick......If it was a dirty MAF the engine should also run noticeably stronger.
(DO NOT touch any of the little tiny MAF wires with anything accept the spray from the can......)
If you have a K&N air filter...throw it away and get a paper filter.
