is this normal?
Oil leaks....gravity and the actual weight of the oil will push fluid through tiny leaks too......and again, over time more will get pushed out. Sometimes when the level drops enough it might not push through a small leak anymore.
What kind of fluid is it....?
Big difference between motor oil and tranny fluid....
Reason being is that most regular mechanics are not familiar with the alignment procedure in these Ls engines and they always end up with a drip and they try and fix it with adding a lot of rtv in the wrong places..
Also the ac compressors are known to drip a few drops of green/oil almost a gel like on to the ground.. Best bet is to crawl under the car with a light and find out
