HELP!!! One year only?
The engine in the 98 cars will also run that badly if the Coolant Temp Sensor is failed or not plugged in.
So its possible you need a 98 cluster. I found this out when I removed my 98 factory cluster to install a new one with a 200mph speedo faceplate. I started my car with the cluster out, just to move it into the driveway and thats how bad it ran. I popped it in....ran perfect. Popped it back out....ran like crap again.
I have also had my Coolant Temp Sensor unplugged and the engine won't really run....plug it back in and runs perfect again.
Weird stuff.....but I've always said that all PCMs are not created equal.....some have minds of their own.
