Sponsored by: CARiD
GM Rear diff fluid
Old Mar 2, 2016 | 08:11 PM
JGL's Avatar
JGL
Default GM Rear diff fluid
Hey guys I'm going to change my rear diff fluid I was wondering what fluid I need and where I can get GM fluid. I have a z28 98 Camaro. Also what additive do I need
Old Mar 2, 2016 | 10:40 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
1998 was the last year for Auburn posi as the base/stock rear, and this unit calls for conventional (non-synthetic) 80w90 lube with a bottle (4oz) of the GM limited slip additive (can be purchased directly from GM); the additive is required for this rear. '99+ received a Torsen limited slip that calls for 75w90 synthetic and the additive is optional (though GM technically still recommends it in the service manual.)
Old Mar 2, 2016 | 10:44 PM
wssix99's Avatar
Save the manuals!
You also need a set of nose plugs. (The stuff smells really really bad.)
You can also get the additive on the shelf at parts stores. I got some at AutoZone that said it was specifically compatible with and met the GM spec.
