Sponsored by: CARiD
Running issue need some help
Old Apr 7, 2016 | 06:22 PM
SwEeTWs6's Avatar
Default Running issue need some help
Hi guys just wanted to say thank you before I get ask my question.... Car is a 98 trans am that I did a cam and spring swap and everything ran fine.... I decided to buy some 799 heads and have them ported and a valve job done... After installing the heads I went ahead and installed a fast 92mm with 92mm throttle body and now the car is running like absolute ****..... popping and running like it has a miss I have a video if anyone would like to see or point me in a direction to start looking at...
Old Apr 7, 2016 | 09:22 PM
Burken01's Avatar
Did you get the car retuned after everything installed?
Old Apr 8, 2016 | 07:39 AM
SwEeTWs6's Avatar
Not yet almost sounds like a vacuum leak and beginning to think the fast intake isn't sealing correctly
Old Apr 10, 2016 | 02:54 PM
SwEeTWs6's Avatar
Ok guys I did a compression check on all cylinders and we are at 150 across the board.... I checked for spark and injector pulse and we are good there... Now here is where I am going nutssss cyliders 2 and 4 are black, 6 and 8 look brand new now if I run the car and unhook all the injectors there is no change in idle same goes for unplugging the coils.... Its almost as if the passenger side isnt even running.... Any suggestions?
Old Apr 10, 2016 | 03:08 PM
Burken01's Avatar
Car needs a tune after those mods.
Old Apr 10, 2016 | 05:52 PM
SwEeTWs6's Avatar
It was tuned after the cam swap.... Spoke with my tuner and he said it should run without any popping or anything.....
Old Apr 20, 2016 | 07:26 PM
SwEeTWs6's Avatar
It was 2 fouled plugs **** drove me crazy...... Thanks all
