Sponsored by: CARiD
jacking under front control arm to load suspension?
Old May 16, 2016 | 01:17 PM
1 FMF's Avatar
Default jacking under front control arm to load suspension?
how can you jack up the front of the car and have the suspension loaded but with the front wheels off the ground?
is it safe to use floor or bottle jack to jack up under the bottom of the control arm, with a piece of wood being the two? that wouldn't harm the control arm would it?
Old May 16, 2016 | 02:00 PM
Spartan7's Avatar
I've used a floor jack and block of wood under the lower A-arm to load the suspension for torquing components (which I assume is what you're doing). Just be careful of the ball joint zerk fitting, if there's one in there.
Old May 16, 2016 | 03:44 PM
SMKE EM's Avatar
From my experience, this doesn't work. Although it loads the suspension it doesn't raise the suspension up high enough to mimick being on the ground
Old May 16, 2016 | 09:21 PM
Majestic9C1's Avatar
jack up the car in the center on the K member and put it on jackstands and then use the jack to load the suspension on whatever side you are working on.
Old May 17, 2016 | 12:49 PM
01ssreda4's Avatar
Stock lower arms are stout. Jack away, no worries.
Old May 17, 2016 | 01:02 PM
1 FMF's Avatar
reason i ask,
if i scribe a chalk line on the front tires... to measure toe with a longacre toe in gauge #79622 "Simply jack up the front wheels and scribe a true running line on the face of the tires"
i thought toe changes when the suspension drops when the car body is jacked up and wheels are off the floor?
By Brett Foote | 2026-06-04 05:00:17
