Sponsored by: CARiD
Wheel toe in drivers side only
Old May 25, 2016 | 10:50 AM
FbodyShuffle's Avatar
Default Wheel toe in drivers side only
I have a 94 Z28 pretty stock other than motor. So my 6 yr old and I were messing around in the Z. I needed to whip a bi**c so I cranked her to the left hammer down going about 30. Heard a clunk from the front end and now my front left wheel is pointing in with the steering wheel straight while right side is straight as a arrow. To get the left wheel pointing forward the steering wheel is at 90 degrees with the right wheel pointing out like it should. I replaced both inner/outer tie rods and it helped a little but still not acceptable. The existing tie rods where bent a little and some play but not terrible. I'm starting to think its the rack and pinion but don't wanna keep throwing sub par parts at it when I'm on a strict budget. Any input would be greatly appreciated thanks in advance.
Old May 25, 2016 | 10:32 PM
MC Ray's Avatar
The clunk you heard could have been a control arm bolt breaking loose and altering your alignment.
