Sponsored by: CARiD
Broken O2 wire
Old Jul 4, 2016 | 03:15 PM
farmington's Avatar
Default Broken O2 wire
Was under my car today and saw a broken wire going to my drivers side O2 sensor (the black wire). It didn't throw a code. Fixed the wire. Car doesn't drive any better but it seemed to run ok before too. Doesn't seem right to me.
Old Jul 5, 2016 | 08:25 AM
wssix99's Avatar
Save the manuals!
Is it the post-Cat sensor and could you have had it tuned out?
Old Jul 5, 2016 | 05:56 PM
farmington's Avatar
Have long tubes. Only use front O2's. Checked FSM and black wire was the ground. Can't understand why it didn't set a code.
Old Jul 5, 2016 | 09:00 PM
wssix99's Avatar
Save the manuals!
Maybe they are tuned out? Could your service engine light be out? (Some people disable them.) Have you checked for codes even though you don't have a light?
Old Jul 5, 2016 | 10:14 PM
farmington's Avatar
Used my obdII scanner and no stored codes. This is a front O2, the rear two are tuned out.
Old Jul 6, 2016 | 02:06 PM
wssix99's Avatar
Save the manuals!
If you can see an actual waveform from the O2, maybe it was getting a satisfactory ground through the exhaust pipe and chassis? (The black wire was just the ground.)
