Sponsored by: CARiD
Coolant Problem
Old Jul 13, 2016 | 12:23 PM
Volcente's Avatar
Default Coolant Problem
Hi to all!
I've a '99 3800 V6 series II Camaro!
I've find these in my radiator, can you help me to understand if it is oil or if It is old coolant?
The coolant is really very old....
Old Jul 13, 2016 | 09:52 PM
LS6427's Avatar
Flush it.
I'm not up on the V6s, do you have a transmission cooler built into the radiator. Could be leaking into the coolant.
But it looks like just old Dexcool......if the V6s also use Dexcool.
Either way...you need to flush it.
Old Jul 13, 2016 | 10:10 PM
67Lark's Avatar
V6 has used dexcool just as long as the ls platform sadly. What's worse is the v6 has a wet intake manifold and plastic gaskets so they fail and cause mucho damage.
Could be dexcool crud or tranny fluid. But to me it looks more like trans fluid. If you have a trans cooler built into the radiator I would recommend checking that out
Old Jul 14, 2016 | 03:26 AM
Volcente's Avatar
OKAY, dex cool is really old and I flush it.
So is possible that it is dexron VI.
okay I try to ceck.
thz
Old Jul 15, 2016 | 11:16 PM
LS6427's Avatar
Oh....DO NOT use Dexcool again. Flush it real good and then go GREEN anti-freeze. Its better for cooling and doesn't make a mess.
