Clutch safety switch
Sometimes I have to bounce on the brake or clutch to get it to finally start up.
Other days, it fires up perfectly.
Should I just replace it or can it be adjusted? It's working fine most of the time.
I'd rather not bypass it.
Thanks!
Thanks!
If I remember correctly it can be adjusted like a brake light switch. I would try to adjust it using a meter.
OP, put a meter across the pins and press the switch by hand, see if you're getting an intermittent short. You can bypass it by shorting the two harness pins together if you're in a bind.
We are talking about the clutch pedal switch, which senses the pedal being depressed and signals the that it's safe to start the car or that the cruise control should be cut off.
This switch is just like the brake pedal switch and is adjustable. It's common to adjust it after a master cylinder change or any other clutch change that would change the pedal travel.
I always assumed that the adjustable one did both...
The anticipate switch senses when the pedal is slightly pressed in. The start switch senses when the pedal is all the way down to the floor.
Now that it's been cleared up for OP, have you tried what I suggested as far as jumping the pins to bypass the switch? It only has two contacts.
I'll need to look up the best way to bypass this switch if i get in a bind. Seems there is a lot of information out there on how to do this.
I checked out the positioning and the clutch definitely touches down correctly on the switch. I'm guessing the best solution is to replace this switch?
If I get a chance again, i'll test it with a meter.
how did your situation end? Did you fix it with a simple sensor change?
