Sponsored by: CARiD
2002 SS overheating help troubleshooting
Old Aug 10, 2016 | 05:00 PM
Wiz02's Avatar
Default 2002 SS overheating help troubleshooting
I could use some suggestions to help troubleshoot this overheating problem before I overheat.
Symptoms - cold start to standard 210 indication on temp gauge normal rate of rise. Driving suburban traffic without a/c 20 minutes no problem.
Cold start with a/c on (a/c blows cold air no problem) temp rise to 210 normal, couple of minutes later temp gauge soars and MIL turns on.
Sounds like a fan right? Here's the twist. Shut off a/c, key off/engine on, temp back down to 210 immediately. Turn a/c on pegs the pgauge again instantly. Do key off/ engine on leaving a/c on and the temp gauge stays pegged.
Suggestions on where to start? Thanks.
Old Aug 11, 2016 | 06:09 AM
wssix99's Avatar
Save the manuals!
The Maintenance light turns on or the Check Gauges light turns on?
Assuming the latter... You have the first step - make sure the condenser is clear of debris and that the fans are running.
Old Aug 12, 2016 | 02:48 PM
smitty2919's Avatar
I believe the fans should come on when the AC comes on. Let the car warm up to normal temp and see if the fans kick on when they should. If they do, then try it with the AC on and verify the fans come on.
Like already said, check for crap in the condenser and blow it out from the back.
If te car has any significant miles on it, and coolant has never been addressed, then see if coolant is low, or sludgy. My 95 with 60k mi had dexcool in it that would overheat when I autocrossed....this is what I found:
Drain plug completely pulled and NO coolant coming out:
Yummy:
Old Aug 16, 2016 | 11:29 AM
Wiz02's Avatar
Thanks Guys - been on vacation for a few days. That's a pretty scary looking radiator pic!
I will take a look to see if something is blocking the condenser. Wouldn't that be a nice fix? The fans are definitely running when the A/C is on, the question is are they running on high or not?
Old Oct 5, 2016 | 12:33 PM
Wiz02's Avatar
So - it's been almost 2 months before I got around to looking at my overheating issue on my 2002 Camaro SS. I open the radiator cap and surprise, no coolant is visible! I start adding coolant and it takes close to 1 gallon to fill it, after I let it run until the thermostat opens and it burps a couple of times to get the trapped air out. Seems to be running fine now with and without a/c on, and there are no sign of any leaks! (of course it must be leaking - where else would the coolant go?) I was all set to do electrical troubleshooting and the issue was the most basic cooling problem - no coolant.
Old Oct 5, 2016 | 03:22 PM
wssix99's Avatar
Save the manuals!
It can go out the water pump weep hole or the exhaust. Time for a pressure test and check the bottom of your A/C compressor to see if it's wet.
