Sponsored by: CARiD
Tail lap lenses are separating
Old Nov 25, 2016 | 04:36 PM
JimMueller's Avatar
Default Tail lap lenses are separating
The bottom edges of the clear lenses of both rear tail lamp assemblies have separated from the other plastic lens edges; if you look along the length of the housing the bottom edge is further rearward. Otherwise the lamps themselves are in decent condition except for condensation due to the gap. Can this be properly repaired or should I replace the housings?
Old Nov 25, 2016 | 05:25 PM
Majestic9C1's Avatar
common problem.. you can try and super glue them back on or get new housings..
Old Feb 1, 2017 | 02:53 PM
JimMueller's Avatar
I swapped it out with a spare tail lamp assembly and replaced the corroded bulbs and sockets. I also drill some small drain holes in the bottom of the lamp enclosures.
