fbody headlights are stuck
You'll see that the gear flip trick only works a small percentage of the time and really only helps if one or two teeth are bad. It's also possible that your motor is pulling away from the gearbox and stripping more of your gear teeth. (This issue even strips metal gears and may cause you to have to get a new motor.)
https://ls1tech.com/forums/pontiac-f...-1967-2002-73/
