Sponsored by: CARiD
Steering rack leaking
Old Feb 13, 2017 | 02:29 PM
Crashz28's Avatar
Default Steering rack leaking
Ok so I just put my car back together after 5yrs of sitting in the garage. It appears my steering rack is leaking none of the hoses appear to be leaking just the rack itself specifically the lower part where the the steering linkage goes into the rack.
So do I need a new rack or is it rebuildabe? Or is there something on the back side im not seeing that is a easy fix?
Attached Thumbnails Steering rack leaking-20170213_135921.jpg   Steering rack leaking-20170213_135915.jpg
Old Feb 13, 2017 | 08:52 PM
RockinWs6's Avatar
Put a few ozs of this in there https://www.walmart.com/ip/K-W-Trans...&wl13=&veh=sem I use it all the time.
Old Feb 14, 2017 | 12:04 PM
ShovelMan's Avatar
Check and see if any of your hoses are
bleed out any air (put front end on jacks, and without turning the car turn the wheel from lock to lock (all the to the left, all the way to the right) 20-ish times.
Old Feb 14, 2017 | 12:21 PM
2ToeRacing's Avatar
most of the time once they leak its time for a new one
Old Feb 15, 2017 | 12:29 AM
Crashz28's Avatar
None of the hoses are leaking and neither is the pump itself. Crazy thing is it leaked when I jacked the front end up to check some other stuff, but after I lowered it down and drove it some got it back home and no more leaking. The fluid in the pump is at the same level. Im confused at this point... Monday when I took found the leak it hadnt started leaking till after I jacked it up which at first I thought it was the pump because of that.
