Need help with Mechman Alternator install
Does the factory plug not work with this alternator?
This is the adapter that came with the alternator. The wire is hanging off of the car side of the adapter, not the alternator side. That is what has me confused. I'm going to call Mechman today and see if I got the right adapter.
Now I just have to figure out where I want to tap this into the ignition voltage.
Since I also have a wideband O2 that I am installing, I might as well do both at the same time.
I ended up tapping into the passenger side fuel injector + line.
DO NOT USE THE EMISSIONS CANISTER POWER CONNECTION. I thought that looked like ACC, but fluctuated from ACC to START.
