Oops. Need to fix Fuel Line
Basically I was setting the car down on some stands and one of the lines got pinched between the car body and a tire. Crushed it pretty flat for a small section a little shorter than 1". I believe it is the return line but I'll verify that when I get some time to dig around a manual or shoebox's website.
I was thinking the easiest fix would be to cut out that section, and splice in some sort of similar steel pipe.
Just wondering what size these lines are and what types of parts I'll need to Frankenstein this back together.
Thanks!
Edit* It's possible it is the EVAP line.
It is the rear brake line and it is very long. If you want to replace the whole thing, its best to pull the old one out and use that as a guide to bend a new one. It will need flares at either end and will need the proper connections. You can also remove it from the car and take it to a shop and basically say "make me a new one."
However, if you don't want to replace the new one, you can splice in a new section there. I spoke with my mechanic friends and as long as proper double flares are made, a union can be inserted and it is perfectly safe and legal. Some people say you should replace the whole line. There's plenty of debate on it around the internet. I'm perfectly comfortable splicing in a section if it is done right and that is what I intend to do. You want to use proper brake line which in this case would be 6mm Poly-armour. Pretty easy to find at most parts stores. I plan on heading to NAPA later.
The hardest part is making good flares (particularly on the old line) but I plan on buying a lengthy section of line and just practicing in my driveway until I achieve brake line nirvana.
I've got plenty more info if you want to know anything else.
