Sponsored by: CARiD
Lq9 cooling issues
Old May 3, 2017 | 05:39 PM
wicked383lt1's Avatar
Default Lq9 cooling issues
Well guys I've been working on this for a while now and can't figure out how to fix this issue. It all started out when I swapped the radiator and installed a lt1 style radiator. It's a new radiator btw. So I thought it was air bleed out all the air and still have the same issue. So then I swapped out the thermostat and the radiator cap. The water pump is new from the swap. Giant figure out what's happening?
Old May 3, 2017 | 05:53 PM
chrysler kid's Avatar
What issue is it having.
Old May 3, 2017 | 06:36 PM
Sorry about that, when I'm in traffic it runs at 185° but on the highway it goes up to 210°. As soon as I get off the highway it troops again.
Old May 4, 2017 | 07:08 AM
Well some things to check for, the first would be to check for any leaks using a cooling system pressure tester. It's possible you have a leak at full pressure (when driving) that does not appear at idle.
Rent a cooling system pressure tester and see if you are holding a steady 15 psi coolant pressure with the system pumped up
Old May 5, 2017 | 11:26 AM
LS6427's Avatar
If you run cool all the time in city.....then overheat on the highway......Sounds like a ram air issue. My LQ9 runs almost too cool on the highway at a steady speed of like 65-70mph.
Is your lower front air dam ok...?
Is there anything stuck up in front of the condenser?
Any work been done lately up front anywhere on the car?
