Sponsored by: CARiD
Hissing from vents when A/C compressor is on
Old May 4, 2017 | 02:33 PM
AdsoYo's Avatar
Default Hissing from vents when A/C compressor is on
Things are supposed to start warming up soon so I tested my A/C today and discovered that when the compressor engages, there's a hissing noise coming from the vents and it doesn't blow cold. Took the climate control panel off to see if the vacuum lines were leaking but they were quiet. The hissing is loudest in the 3 center vents. Hissing doesn't change with blower motor speed. Goes away when I switch to anything besides A/C. Tried listening under the hood but couldn't hear the hiss, saw the compressor was spinning. The noise is only present when the compressor is engaged.
Old May 4, 2017 | 06:19 PM
AdsoYo's Avatar
I'm driving from central Oregon to Vegas tomorrow so really wanted to get this figured out. Luckily I found a shop that was able to check out the A/C right there in the parking lot. They added 1lb of freon and it's all good! Blows ice cold and no more hiss.
