Sponsored by: CARiD
99 bird wont crank??
Old May 12, 2017 | 05:24 AM
99problems's Avatar
Default 99 bird wont crank??
​​​​I recently purchased the car as work in progress daily driver. First month ran like a charm and then decided to get me. Began to get hot and shut off along with me going to thru 3 starters and now it doesn't even turn over starter as if battery is dead?!? Take battery out put in other vehicle and fires that one up. Any ideas where to begin it recovery and return to the road. Thanks
Old May 13, 2017 | 07:18 AM
wssix99's Avatar
Save the manuals!
Welcome to the site. Can you give more information on what happens before and now when you try to start the car?
So, was the car shutting off on you, then it wouldn't start?
Did you change the three starters and test the battery in response to the car not starting or cranking?
Have you tried jumping the car, anyway?
