F-body keyless remote diagnostics
I guess I'll see if my local Autozone has a fob tester. What other diagnostics can I perform in lieu of throwing money at random parts? Could it be a BCM problem separate from the loose solder joints which intermittently cause the window/radio issue?
Edit: I read elsewhere "you hold LOCK and UNLOCK, and then release, and then hold LOCK, and the door locks will cycle again. Turn the key to OFF and you are good to go." I don't recall the manual saying to release L/U and the hold L. Let me try that....nope, no change, and the manual doesn't say anything about holding down L again.
The other related agitation I have is that sometimes my drivers side lock will be very difficult to turn with the key (to the point where I feel I might break the key), and also when inside sometimes the unlock slide lever will be very difficult to slide, if it moves at all. After I took the door panel off, I couldn't duplicate the problem, the arm would slide normally. Is there something in the design that would intermittently cause that issue?
