Differential Cover Gasket
Back in January, I drained my rear end, put a new Gasket on, put the GM post fluid in, and filled the differential up with fluid. Since then, the cover has been leaking. When I put the Gasket on, I used RTV on the cover, and the housing, as I was told to do. When I asked the same person about it leaking, he said I probably should've just put it on one side (can't remember if he said housing or cover). As a GM dealership tech, I have access to online service manuals for GM cars, and when going through the cover Gasket procedure (after the fact), it made no mention of using rtv.
So, my question is, where do you think I went wrong? Could it of been that I used rtv, or put it where I shouldn't of? I have everything I need to do the same job again, so I want to make sure I do it right this time.
Thank you in advance
I clean the sealing surfaces with a green Scotch Brite.
Then I put mega black oem gasket maker on the differential. Then I put some on the differential cover.
I use a gasket also, some don't but I do. Put the gasket on the cover then put it on and bolt it up but ONLY tighten the bolts finger tight and let it set for a half hour then bolt it down. Good to go
Also if it's a Auburn differential I would add 2 of the 4oz limited slip additive and use conventional gear oil.
Even tho it's not necessary if it's a torsen diff I would still add 1 bottle of GM ac Delco limited slip additive with convention gear oil.
I don't typically use any sealant on these, other than maybe a bit around the bolt holes which also helps to hold the gasket in place, just a GM gasket (one of mine came from the factory with a double gasket - not sure if this was a mistake, but it wasn't leaking at all.)
Good advice about the LSD additive mentioned above for the Auburn rear. But the OP wouldn't have that in a '99 Z28 if it's still the stock rear. '98 was the last year for Auburn unless you ordered the SLP Auburn on an SS car in '99+.
I'm sorry, I feel like I'm making this more difficult than it needs to be, but I just want to make sure I do it right this time
I usually go in a pattern kinda like a intake manifold
This is why I service my own vehicles.
I changed the fluid and gasket on Tuesday, and so far no leaks. Thank you everyone for your time and help
I have been a truck tech for over 40 years and just changed the oil on my wife's 16 Enclave, how do you get the filters off without making a huge mess?
Don't let people get you down, your young and learning, not everyone is a internet expert. I tell all my new techs that the reason us old guys know so much is because we already screwed up that job and learned the right way when we fixed the screw up. Glad you got your leak fixed.
And thanks, I understand where he was coming from, though. Just saying I was a "GM tech" is misleading, haha
Thanks for all of the help, everyone
