Sponsored by: CARiD
How to disassemble ttop?
Old Jun 10, 2017 | 06:53 PM
Whisper's Avatar
Default How to disassemble ttop?
So Ive been trying to use the sticky for using RTV on a leaking ttop. But that came to a quick stop since there's no explanation on how to take the damn thing apart. There are two obvious screws but how do I remove the handle so the plastic shroud has room to clear and come completely off? Search, nor youtube nor google has any information.
Old Jun 10, 2017 | 07:23 PM
98CayenneT/A's Avatar
If you look under the handle, where it connects to the shaft you will see a metal clip. It is like a horse shoe clip and can easily be pulled out with a small flat head screwdriver then the handle will just slide off
Old Jun 10, 2017 | 07:29 PM
While you are in there throw some grease on the latch assembly
Old Jun 16, 2017 | 02:47 AM
Phoenix'97's Avatar
True that, I forgot to do it the last time I fixed my leaking T-tops with flex shot. I guess I don't mind the resistance, ha ha. That horseshoe clip is a PITA to get out though, having to find one end and pull it out and then find the other end and pull it out to free the head of the horseshoe clip.
