Sponsored by: CARiD
Motor mounts
Old Aug 12, 2017 | 12:11 PM
Road_House's Avatar
Default Motor mounts
What is everyone using for replacement motor mounts? I just need the 2 polyurethane mounts that attach to the motor and im going to keep the stock ones that attach to the k member.
Thanks!
Old Aug 13, 2017 | 05:53 PM
sjsingle1's Avatar
I used the prothanes...in red....i also used the spohn pedestal mounts.....saves about 15 pds of dead weight
Old Aug 14, 2017 | 08:48 AM
Road_House's Avatar
how do you replace the poly mounts inside of the steel case? My stock rubber is inside of the steel case by big rivits
Old Aug 14, 2017 | 12:46 PM
LeadfootDuramax's Avatar
You drill the rivets out and bolt the clamshell around the poly mount.
Old Aug 14, 2017 | 04:01 PM
sjsingle1's Avatar
you also have to wire brush all the leftover rubber crap after splitting the shells.....I used a good quality water proof grease in the shell and on the poly to ensure there was no squeaking from the poly moving in the shell
the bolts to hold the shells together are included in the prothane kit....the bolts only hold the shells together until the mounts are bolted to the block
Old Aug 17, 2017 | 08:18 AM
Road_House's Avatar
thanks for the tip, I ordered them, hopefully it's a smooth drilling process.
thanks again for the replys fellas
