Battery voltage gauge dips
Could this be a ground issue somewhere? Or is this just normal behavior? I don't remember seeing the needle twitch prior to when my issues with the alternator and water in tail light started. Thanks.
I ran a 4 gauge ground from the block to the chassis (no longer have rear alternator bracket so used mounting hole for that to attach to block and attached other end to ground screw near driver side strut tower as seen in pics). I was trying to find the factory ground strap that connects near the alternator to the chassis and after looking for it for 10 minutes I realized it was in front of my eyes the whole time but way smaller than what I was picturing in my head. I tagged it in the photo. I already had a ground jumper from battery to passenger side strut tower area but I replaced it anyways.
After all this, the needle still momentarily dips any time I apply brakes or turn on headlights or defroster etc. I uploaded a video that shows what I am seeing any time an electrical load is applied. Dips for a split second and then goes back to normal. I am starting to think it's related to the alternator itself unless anyone else has some ideas to try.....over all the car is running fine but I'm concerned that could change. The alternator was a used one from a 2003 Hummer with approx. 40k miles on it, been in the car for about 9 months.
The stereo effect on the battery gauge is just the latest thing I've noticed. Even with the stereo off and all other electrical off, I still notice higher than expected movement of the needle when say just the turn indicator is on. I am starting to suspect the alternator. It can handle high current loads (all electrical on in car and voltage steady at 14.75 volts), but it doesn't seem to keep up with the transient changes in load very well. I'm not even sure if alternators are supposed to deal with transient changes or if a stiffening cap is required. I just wanted to keep updating this thread until/if I find a solution. I may post on the stereo forum to see what others might have done. Thanks.
https://www.youtube.com/watch?v=wdfI...ature=youtu.be
