Headlight Intermittently works.
https://ls1tech.com/forums/pontiac-f...s-go-here.html
i would start by looking at all connectors. they typically like to corrode over time. clean everything up and see what happens.
The connector is located on the frame stuffed between two wedges behind the headlight motor assembly.
If you have stock bulbs:
- The bulb connector can loosen up. Pinching the bulb contacts a little closer together can fix this problem.
- Some Sylvania replacement bulbs were known to be bad out of the box. (If your bulb is old and was reliably working for some time then you don't have an issue here.)
