Sponsored by: CARiD
Driver side lights not working
Old Apr 3, 2018 | 08:31 AM
mngoos's Avatar
Default Driver side lights not working
2000 firebird the driver sides headlights are not working low or high beam. Fog and turn signals are working. Help I work graveyard and need to get this fixed asap
Old Apr 3, 2018 | 09:04 AM
bleepster's Avatar
burned out light? check for power at the connector to the light. they get corroded over time and/or get loose
Old Apr 4, 2018 | 06:41 AM
wssix99's Avatar
Save the manuals!
This is a common problem with multiple causes. The typical causes (that I recall) are:
- bad ground on that side of the car
- corrosion in the headlight motor connector (the bulb wires go through it)
- loose connector at the bulbs
- burned out bulbs
- a combination of one or more of the above (it happens)
Old Apr 4, 2018 | 07:02 AM
WhiteBird00's Avatar
Ungrounded Moderator
You can probably eliminate the first one (ground problem) in this case since the turn signals and fog lights share the same ground with the headlights on each side.
