K member concern.
My car has a similar affliction from an 8" curb brought on by an abrupt end to two 360's across a frozen bridge. It's a pretty stout plate and I would think you are fine as long as you don't see any cracking. My car has been fine for 4 years with this "feature". I just needed an alignment. I aspire to replace the K Member, but will probably only do that when I pull the engine.
Many on this site would debate if a driven car can ever be called "mint," (unless it's green) let alone one that's seen any normal abuse, but if you want to get the car closer to the same it came out of the factory, you may consider a junk yard part for this one. Before you do a replacement, you should shop carefully. I recall some suppliers of aftermarket tubular K members (aftermarket design - if you want to go that way) have had problems with cracking on cars used for street use.
As long as there is no cracks and your alignment is good, then it should be okay to drive it still, but it looks like it would have at least moved the lower mounting points in some.
lol
