Sponsored by: CARiD
Rough Cold Start, Wants to Die
Old Jun 19, 2018 | 11:09 PM
iPlink's Avatar
Default Rough Cold Start, Wants to Die
Hello all:
I am new to this forum in the sense of being a member. I have used this forum and a couple others for information to remove motor and transmission and later on reassemble and install them to the car. I have tried searching over the past few weeks and trying different things out to see if I could find the problem. The idle was fine before motor removal but now has an issue to where it wants to kill itself. I have tried propane enrichment to no success in the hopes it would expose a vaccum leak. I changed the IACV and TPS sensor with AC Delco parts as read on the forums, and reset them. the car has a high idle if i push the plunger of the IACV and install it, but once it makes its adjustments it goes back into its rough idle and jerky stall out and code p0506 lives with me. It is a 1999 trans am with a 4l60e. I have pulled a couple of segments of the start up runs with an HP tuner and am just looking for a way to start narrowing this issue down. I think I may need to take my time and go through the wiring and maybe add a ground or 2. As i only remember adding like 2-3 when i put the motor back in. I feel like 2 around the driver headlight area and another on the passenger side. If it will be a help to have the HP tuner files, please let me know and I will find a way to post them here. If anyone is able to help me I will greatly appreciate it.
Thanks.
Old Jun 20, 2018 | 02:05 PM
BALLSS's Avatar
does this rebuilt motor have the stock cam?
Old Jun 20, 2018 | 02:51 PM
iPlink's Avatar
Sorry motor isn’t rebuilt, it is the original from when I got it. I had to pull tranny and send it to performabuilt to get fixed. It doesn’t have a stock cam though. I took a pic of the numbers that were scribed on the back side of the motor on the cam.
Old Jun 20, 2018 | 07:57 PM
bigbomber5's Avatar
Check fuel pressure? Clean MAF?
