Sponsored by: CARiD
Charcoal particles?
Old Jun 25, 2018 | 07:45 PM
Jeff 97 Formula's Avatar
Default Charcoal particles?
A few weeks ago I got a check engine light which gave me code P1441. It turned out to be the EVAP purge solenoid (I was able to blow right through when it was not energized). I replaced it, and no check engine light ever since.
However, I decided to tap on the old solenoid and this is what came out. Are these particles from carbon that gummed up the valve or are these charcoal particles meaning that my canister is shot and I need to replace it?
Old Jun 26, 2018 | 01:32 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Those are particles from the canister. The canister, and the EVAP system in general, is an emissions component, so how you wish to handle it may depend on your need for emissions compliance.
Old Jun 26, 2018 | 08:06 PM
Thanks...I just ordered a new canister and a spare purge valve cause I'm in NJ and need to be emissions compliant. Is the canister difficult to replace (I know where it is, and it seems to be strapped in a tight spot behind the wheel well).
