Testing for Bad Headlight Motor or Module
Another thing that confuses me is I hooked the motor up to the battery and it did nothing, so I also thought maybe the motor is bad. I got a new one and did the same thing with that, it does not cycle either. What am I missing here?
I'm also unclear on how the voltage reads at the connector on the body side, since I couldn't get hardly any voltage to read on either side, does it need to see a load in order to read a voltage? Like I'd have to back probe the connector when running the motor to see anything? Because the driver side works fine, but when I pulled the connector, hooked my meter up to it, turned the headlight switch on, i got less than a volt. Yet that side still cycles the motor. I want to make sure I don't have multiple issues going on here.
