Sponsored by: CARiD
Car started overheating?
Old Jul 10, 2018 | 08:27 PM
Mike1711's Avatar
Default Car started overheating?
Hi I have a 98 Pontiac firebird. My car started overheating today. I drove it for about 1 hour and after I parked it and started the car again and drove the car the gauge showed it’s over heating and going back to the middle gauge. Couple months ago it was overheating but I got the hose where it was leaking from replaced and also the thermostat. They had also done a coolant flush once they done the repair. Does anyone know what might be the issue? It does not stay over Heat. It overheat for a couple of seconds and goes back to normal temperature and starts to over heat again. The cooling fan does start running once it starts to overheat.
Old Jul 12, 2018 | 02:11 PM
Nathan C's Avatar
It could be normal. As the engine gets hot the fans turn on and cool it down. Is it a v6? What temperature does it get to?
Old Jul 12, 2018 | 06:19 PM
Mike1711's Avatar
Hi actually it is not normal because usually it goes 210 in the middle arrow but now it is going a little further to right in the middle arrow before 260 temperature. The fans turn on when it gets hot but at the same time the temperature goes down back to normal even when the fans are not on. Im not sure what exactly the issue is. I had the same problem where the car was overheating and I had got that fixed. Im thinking it can be a radiator cap that was replaced or also the thermostat.
Mike1711's Avatar
Yes it is a V6
Old Jul 12, 2018 | 06:23 PM
2ToeRacing's Avatar
Check the water in the radiator,make sure it full.
Old Jul 16, 2018 | 10:01 PM
LS6427's Avatar
Probably just a failing coolant temp sensor. Needle movement like that is absolutely not normal. Change the sensor. If that doesn't fix it return it for a refund. Just tell them you never installed it.
