brake lights out
It is quite likely that your switch is in fact the source of the problem but I would hate to replace it without testing to confirm. Since you have difficulty with the wire colors, you could go by the wire positions in the connector. You're looking for connector C216 which is a flat 11-pin connector attached to the steering column under the dash (there is another flat connector there that is similar but is not attached to the column). The connector has only 10 wires leaving an empty pin at one end. The wires you want to check are at the opposite end from the empty pin. The end wire is the input from the brake switch - test for power there when the brake pedal is depressed. The next two adjacent wires are the output to the tail lights (right and left respectively). Test them for power when the brake pedal is depressed. If you have power on the end wire but not on the next two then you know the switch is faulty and must be replaced. If you don't have power on the end wire then you have a problem with the connection between there and the brake switch.
