Sponsored by: CARiD
Misfire after working on the car.
Old Sep 12, 2018 | 08:54 PM
jimmyp3353's Avatar
Default Misfire after working on the car.
Changed plugs and wires over the weekend and the car was running fine. Made a 50 or so mile drive, shut off the car and let it sit for a while. When I got back in the car an hour or so later it was misfiring bad under load. Like if I put the pedal to the floor it would miss bad about 2k to 3k rpm. It's like it has a 2 step lol. When driving an you put the pedal to the floor it just misfires and pops and backfires. Put another set of plugs and wires on it today and the same thing. The plugs I pulled out that were only a week old were all black. Only thing I can think of is maybe I jostled something while working on the car maybe. A ground or something?. Cant seem to think of anything. Thoughts? Car is full bolt ons and cam car with a T56.
Old Sep 12, 2018 | 09:54 PM
jimmyp3353's Avatar
I should also add that it takes cranking the car for a good 10 seconds before it starts now.
Old Sep 13, 2018 | 07:25 AM
wssix99's Avatar
Save the manuals!
You should have it scanned for codes. You could have a sensor unplugged or damaged. The codes may give you a clue as to where the problem is.
Old Sep 13, 2018 | 10:02 AM
jimmyp3353's Avatar
No codes believe it or not. But I'm pretty sure I found the problem. The wire loom that goes from the ECU down to the starter, crank sensor....got burned through. The one that had the heat resistant tape or whatever that is on it. It must have been laying on a header tube. The wires look to be ok (i haven't pulled the harness out yet. Just from what I can see with the flashlight) but I'm sure they're not. I have to go through that section of the loom and see. I'm sure the crank sensor wires got damaged.
Old Sep 13, 2018 | 03:33 PM
wssix99's Avatar
Save the manuals!
Even if you have a small cut in that harness and its grounding on the engine, that could cause big problems.
Old Sep 13, 2018 | 03:35 PM
Toes's Avatar
Cracked plug or loose plug wire
