Sponsored by: CARiD
Electrical issue. Alternator?
Old Oct 7, 2018 | 05:08 PM
Eatinstang4life's Avatar
Default Electrical issue. Alternator?
So barely drive the car. Been autocross this year. Had walbro255. Anyhow same thing happened last year no further issues up til today. Both days super hot outside. Today after autocross fuel pressure drops and is Jumping. Battery voltage tests fine 12.5. Although I had to jump start after it stalled. Gauges going crazy etc all way home while limping on the jumping fuel pressure. Got home let cool started up and all is normal!?
Old Oct 7, 2018 | 05:15 PM
8.Lug's Avatar
Where did you get the walbro? Lots of fakes out there. Pretty much have to buy it directly from walbro or from a large retailer like jegs/summit etc.
Old Oct 7, 2018 | 05:45 PM
[quote=8.Lug]
[/I
It's authentic had it for 9 years. Also checked voltage alternator is putting out 14.5
Old Oct 7, 2018 | 06:07 PM
8.Lug's Avatar
Redo the cables for your battery.
Old Oct 7, 2018 | 06:54 PM
I was thinking about that. Any irony that both occasions this happened it was super hot outside? Alternator issues occur with heat?
Old Oct 7, 2018 | 08:11 PM
B52bombardier1's Avatar
Is that measured 14.5 volts all DC? Did you measure or see any AC on your meter? Much more than a tiny amount (less than .02 VAC) means you have leaky or blown rectifier diodes in your alternator. And AC is not good for a lead acid battery or DC-loving devices.
Rick
