Sponsored by: CARiD
Rough idle/hunting on warm start only.
Old Oct 14, 2018 | 01:32 PM
oddwraith's Avatar
Default Rough idle/hunting on warm start only.
Hey there. Car is my 01 with small cam, stock manifolds, lid tune etc. Cold start is fine, but warm startups it idles low and wants to stall for about a minute. Then evens out. Car was running fine before so not the tune, also checked for vacuum leaks. Could this be a coolant or tps sensor? Thanks for any help or knowledge of such symptoms.
Old Oct 14, 2018 | 02:05 PM
oddwraith's Avatar
Also no codes. Engine seems to pull timing/cut power for a quick stutter under wot at around 3,000 rpm. Although, I'm almost certain this is unrelated and likely timing being pulled from the knock sensors registering my banging exhaust.
Old Oct 15, 2018 | 02:30 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
The two issues could certainly be related. Do you still use an MAF (I ask only because you mentioned an aftermarket tune, so I don't want to assume anything)? A dirty MAF and/or poor O2 sensor readings could account for one or both of those issues, depending on what sort of tune you have.
