front cowl water drain
1999 Camaro.
Someone of you know where is located the cowl water drain under the whipers motor cover?
I see a drain hole in the middle that drain rain water over my air intake manifold and I dont' know if it is normal.
thanks for your help
People run the hose over the cowl, then pop the hood to see where the drainage is coming from, then they seal it with silicone/RTV/weatherstripping to keep the water out. Should be fairly simple, however I have never checked if it was normal, but I would avoid it if you can.
I don't want to use siliconeor rtv on the cowl plastic cover because it became difficult to remove in future.
what do you think?
I can't imagine it being an issue but do keep an eye on where the water is traveling after your weatherstripping is in place, want to be sure you're not just shifting the issue onto some other important parts.
Maybe somebody will chime in with some fixes they have applied. I know there are a good amount of threads out there talking about this topic, I just can't seem to find one specific thread that had some really good info in it.
I have see in some photo that there is some metal "bridge" of the body on the cowl under the plastic cover, so I think that the water that comes from the widescreen to the air intake flowing on this "bridge".
If I put a weaterstip at the end of this "bridge" I think the water can go in the right part of cowl.
Then is important to seal the part where the plastic cover become together and the pin.
I see what I will find under the cowl cover in this topic:
https://ls1tech.com/forums/drag-raci...-ps-wiper.html
Thanks for your help and sorry for my bad English!
