Sponsored by: CARiD
Seal the Cowl
Old Jan 25, 2019 | 12:34 PM
Volcente's Avatar
Default Seal the Cowl
Hi to all!
I have a '99 Camaro and the cowl leaking rain over the engine.
I've removed the cowl, both parts, and I've replaced the weaterstrip with a same tipe.
Not good idea, io continue to let the rain comes underhood.
Somebody of you have solve the problem?
I think is better to use a weaterstrip.
Old Jan 26, 2019 | 08:11 AM
RockinWs6's Avatar
Get silicone chalking then use it to seal all along the front edge of the cowling. Also underneath the cowling you need to seal each plastic rivet and hole. I use a rubber glove then put the silicone chalk on my finger tips and work it into every hole and rivet. Then test it with water till every leak has stopped.
Old Jan 26, 2019 | 08:32 AM
Volcente's Avatar
I prefer not use silicone because then is difficult to open and inspect.
Can I use silicone on the plastic rivet but I wantto use weatherstrip on the front edge.
do you think it is the same?
Old May 2, 2019 | 12:09 PM
Volcente's Avatar
I've seal the cowl.
I've used the D weatherstrip and sylicone.
Easy to remove if i need and clear work.
now it is sealed
many thanks!
