Sponsored by: CARiD
Slip in steering wheel
Old Mar 28, 2019 | 05:58 PM
ND4SPD _SS's Avatar
Default Slip in steering wheel
I have a 2000 Camaro SS. Has 192k on it. I'm having trouble pinpointing the cause of this slip i have in the steering wheel before it actually starts turning. Its about 1in and a half to 2 inches. I read about the rag joint but heard that's older 4th gens. Any help would be appreciated
Old Mar 29, 2019 | 02:05 AM
sjsingle1's Avatar
there is no rag joint in the later birds....they are small U joints...2 of em.....upper and lower.....they could go bad but i would check the tie rods........inner and outer
Old Mar 29, 2019 | 09:22 PM
ND4SPD _SS's Avatar
Thanks ill look at those. Hopefully I find something
Old Apr 4, 2019 | 12:45 PM
jaxcam02's Avatar
When I did my headers, apparently I did not push the input shaft on the steering rack enough. That first drive the steering was sloppy and loose. I had to readjust that connection and tighten the bolt down good. After that it was good.
Just ensure the bolt on the connection hasn't loosened and allowed the input shaft to slide off the rack a little bit.
Old Apr 4, 2019 | 01:14 PM
ND4SPD _SS's Avatar
Yeah tried that. Ikno what you mean tho. Gonna recheck everything again. Thanks guys
