Sponsored by: CARiD
C5 Engine wire harness mod recommendations
Old May 10, 2019 | 06:25 PM
C5SixSpeedZ51's Avatar
Default C5 Engine wire harness mod recommendations
Well, my wire harness is showing wires and I have a few broken ones, I'm sending the harness out to be refurbished to a shop in Dallas. He says he can make any mods or changes to the engine harness while he has it, so I need a few opinions on what I need to do in order to battle heat from the headers I'm running. Kooks LTs. Can the harness be lengthened to run it away from the exhaust or should I just have him wrap the wires in heat wrap then a loom over the top? I am going to have him lengthen the TB and Maf wire about 2 inches also. Maybe delete the rear 02 wires too. I am debating on running a msd 2 step also. Be nice to have it all done the way I need it. Any recommendations?
Old May 10, 2019 | 06:32 PM
Shop im using is called LSwerX in Texas
Anyone used this shop?
Last edited by wssix99; May 11, 2019 at 07:52 AM. Reason: non-sponsor graphic removed
Old May 11, 2019 | 07:53 AM
wssix99's Avatar
Save the manuals!
Yes this can be done and is done. If you check out the Vendor Directory link at the top of the page and search for "wir" there are a few shops that do harnesses and at least one definitely does custom.
For your problem, you might check out one of the engine sections or hybrids and conversions. The folks there need to do custom wiring solutions all the time.
