Rough Idle/fuel smell
I have hooked up my scanner multiple times (bluetooth obd2 and the torque app)
Im not throwing any codes but i will let you know what i have noticed.
When the MAF was disconnected i threw a code but my dash never lit up (i know the light works because i had to replace the led for it and i see it light up when the car starts.)
During some live data monitoring i have noticed cylinder 6 and 8 have 2 misfires each incredibly briefly and then none for a extended period of time. (iv only seen this once) After running some data logs i have also noticed misfires in cylinders 2 and 5 again a count of only 2.
I have also noticed some failures in the mode 6 data however it being mode 6 data its accuracy is questionable. (TID: $0c CID:$20 misfire counts for last/current driving cycles(calculated) max:278, current: 53000 TID: $0c CID:$30 misfire counts for last/current driving cycles(calculated) max:153 current:63000)
I have also started noticing a fuel smell, which is new, its normally only at startup and i smell it occasionally going down the road (i dont see any leaking fuel around the injectors and the ohms reading was accurate)
i am at about 21hg vacuum i believe (which from the research i have done, that is about right)
The idle is not steady, it floats up and down from about 790 to around 805
I appreciate any help that is provided, i also apologize in advance if this is in the wrong place.
Logs are also attached for those who wish to view them, if they can be useful.
Mike
I decided to unplug the maf and run the same route and data log as well. No misfires and the idle was definitely better. I know that just because it ran better with the maf disconnected doesn't mean I have a bad maf. I am open to suggestions.
Anyone?
